09ApexOEMplus
2.4L Lancer Gts Specifications
11 posts in this topic
Engine
Standard Engine: 2.4L I4
Cylinders: 4
Block Head Material: Aluminum
Number of Valves: 16
Valve Configuration: Dual Overhead Cam / Twin Overhead Cam
Compression: 10.5:1
Displacement: 2360 / 144Bore X Stroke: 3.50x3.80
Horsepower @ RPM: 168@6000
Torque @ RPM: 167@6000
Red line: 6500 RPM
Fuel Type System: Gas Engine / Multi-Port Fuel Injected
Power to Weight Ratio: 18.1
Transmission
Transmission: 5 Speed Manual/6 Speed CVT (continuously variable transmission)
Overdrive Transmission: Yes
EPA Class: Compact
Fuel Economy Cty/Hwy: 21 / 28
Combined Fuel Economy: 23
Cruising Range: 351.9 Miles
Capacity and Volume
Cargo Volume (EPA): 12 cu. ft.
Cargo Volume (MFR): 12 cu. ft.
Fuel Capacity: 15.3
Passenger Volume (EPA): 93
Passenger Volume (MFR): 93.5 cu. ft.
Brakes,Steering, Suspension and Tires
Brakes (Front): Ventilated Disc
Brakes (Rear): Disc
Drive-line: Front Wheel Drive
Steering: Rack & Pinion
Steering Diameter Left: 32.8
Steering Diameter Right: 32.8
Suspension (Front): Independent MacPherson strut
Suspension (Rear): Independent Multilink
Tire Type: Passenger
Tire Width: 215 mm
Tire Aspect Ratio: 45
Tire Construction: Radial
Tire wheel Diameter: 18 in.
Front and Rear Wheel Material: Alloy
Interior Dimensions
Seating (Standard): 5
Headroom (Front): 39.6
Headroom (Row 2): 36.9
Hip room (Front): 53.3
Hip room (Row 2): 54.1
Leg room (Front): 42.2
Leg room (Row 2): 36.1
Shoulder Room (Front): 54.7
Shoulder Room (Row 2): 54.3
Seating (Maximum): 5
Exterior Dimensions and Weight
Curb Weight MT: 3043
Curb Weight AT: 3120
Ground Clearance: 5.8
Height: 58.7
Length: 180.0
Top Type (Standard): Hard Fixed
Track (Front): 60.2
Track (Rear): 60.2
Weight Distribution AT (Front): 60
Weight Distribution AT (Rear): 40
Weight Distribution MT (Front): 59
Weight Distribution MT (Rear): 41
Wheelbase: 103.7
Width: 69.4
Doors (Standard): 4
Doors (Maximum): 4
Crash Test Ratings, Sales and Origin
Crash Test Rating: 5* / 4*
Where Built: Japan
Engine
Cylinders: 4
Compression: 10.5:1
Red line: 6500 RPM
Transmission
EPA Class: Compact
Capacity and Volume
Fuel Capacity: 15.3
Brakes (Rear): Disc
Tire Width: 215 mm
Interior Dimensions
Height: 58.7
Length: 180.0
Track (Front): 60.2
Track (Rear): 60.2
Wheelbase: 103.7
Width: 69.4
Doors (Standard): 4
Doors (Maximum): 4
Where Built: Japan
Very accurate for the 2009-11 USA models
Mine says I'm like 4 k lbs
Do i just have a fat girl?
Yup 4k lbs. Says it in the manual.
Thanks for the info
and also very sexy!! great info!
I dont think i have ventilated front disks and i know what they are...mines a 2011 also....and the 3k pound if for the GTS, not ralliart or evos
I think almost every vehicle has vented rotors in the front... I've worked in a garage for years and years and can't remember every seeing non-vented front disks. I put ALOT of highway miles on my car (75 mile round trip to/from work) and I often get well over 30mpg. Once hit 34.3!
good find on the specs and the curb weight is not the same as the GVWR which is on the doors and owners manual. GVWR is the weight of the car and fuel and a full load of people and stuff to not go past the 800 lbs overall payload of car.
Is the chassis the same dimensions and setup as the evo?
