leprechaun1874
Interior Lights
17 posts in this topic
I added some led strips under the dash. They come on when the door opens.
112A778F-8F8F-44C8-B62D-4F16506EEAC2-169
Looks good! I have blue ones as well
These are white. Not sure why they look blue in the pic.
Where did you mount the driver side? I can't really figure out where to mount my strip. Looks good though
Simple yet convenient and enjoyable mod!
I mounted both sides to the plastic pieces under the dash
5F7BEA2E-8BB6-4777-888D-F12CF1B27B0D_zps
That looks really nice, I like how they aren't obnoxiously bright haha
what did you wrap the zip ties around? did you drill a hole?
Yea, I tried using some double sided tape. It was meh. So I just drilled 6 holes (3 zip ties) per light. I am thinking about doing it to the back also, but I almost never have people in the back so I'm not sure. I do plan on adding some lights under the door when it opens. Something like this. But have to wait for some warmer weather.
(not my picture)
http://i.imgur.com/VVkFN.jpg
that makes since. right now I have mine wedged in between the dash liner and the plastic. it falls down often. sometimes behind the cover
I like the led lights on the door idea, but how would we wire them? There's no electrical on the doors
And your under dash lights look good!
Thanks. Run the wires into the door and through the jamb to the fuse box.
I wanna try to wire up ones that are underneath the door, so when you open the door, the ground lights up, so i can knock off my boots before i get in the car, dont wanna get a tooo dirty :D
I wanna do this for my car but dont know how to install them :/
OK, here's what you need to do.
Figure out where and how you want to mount your lights. Also, figure out what lights you want. After you get all that done, you will hook the GROUND of the lights to [yellow wire] on the {white 6 pin plug} at the fuse box. I'll have to look at my connections, but there is a hot wire right there also. I'll get that info tomorrow and post it up for you.
looks good
