MINE
Mine Progress Thread
132 posts in this topic
Haha yeah don't want anything catching fire that's for sure! Pics of new stuff?
Will probably take a few tomorrow
It's been a while, so here is the update:
SpecD Tuning Projector Headlights
Interior Painting Complete
Summer Rims (White 18" stock ralliart rims)
Engine Bay Paint Job
Rear Flaps
Kermit Sticker (Picked up at Clean Culture)
She needs a good wash still
Still To Do - Lots :)
Finish Seat Warmer Install
Vortex Generator
Handle/Sunglass Case Swap
Headliner
Speaker Upgrade
Sound deadening
Hood Dampers
Fuse Box Relay
12V AUX port
Sill Plates
And the list goes on...
Like the covers
Regards Al
You Pies!
Thanks, I have to do a little bit of touch up, since with the engine heat the dip shrunk a bit on the mitsu logo
I've been busy today... she still needs a wash though
Seat warmer install complete
USB port relocated
Fire extinguisher mounted
and the glove box still opens
Thanks to fastcar123 for his HVAC replacement tutorial, helped for taking out a few parts
how did you do your seat warmers? im curious about this
It was a real pain lol
bought carbon fiber warming pad kit. the seat covers are in 2 pieces - one for the backrest and one for the seat. the back rest was pretty easy - the cover has these plastic clips under the seat (2 of them), then a long clip along the back of the seat down low. I unzipped the backs after the frist two clips and slid the long one out sideways instead of pulling it off since that was way easier. at that point the backrest cover could be lifted in the front and I slid and adhered the pad in place.
the seat part was a real bear. after the backrest pad is in place i removed the plastic panel along the outside of the seat by the backrest angle adjustment lever. this gave me access to the clips that go along the entire rim of the metal seat frame and I was able to pop them off rather easily (with the panel in place it is nearly impossible). then peeled back the seat cover as far as I could to find yet another obstacle. the style lines in the upholstery are held in place by plastic rods sewn into the seam with are connected to metal rods in the seat by metal rings. I cut/bent/removed the ring in the middle of the seat, put nothces in the outside of the pads for where the other two rings would sit, then forced the pad into place without popping any of the other rings. Make sure the electrical tails are accessible and restore the seat covers, making sure the style line plastic piece is flipped the right way so it sits naturally (you'll know if it's wrong). I removed the center console, ran the switch leads up and into the space below the cup holder, cut holes for the switches with a dremel, ran the power and ground lines to my aux fuse block behind the glovebox. Buttonned it all bakc up and bingo, there you have it.
They warm up pretty fast, looking forward to using them in the Buffalo winter.
The hardest part is getting the seat pad in place and dealing with those style line plstic pieces. The first seat took me a solid 2 hours to figure out, the second took me about 30 minutes in the freezing cold and with another set of hands to hold things back/in place. I definitely recommend having a buddy - that second set of hands made it so much easier.
Unfortunately I do not have pics, but I can make up some drawings to better illustrate the process if you'd like
actually I wouldn't mind seeing those drawings. Whats great is I actually don't like butt warmers but I do like back warmers. got any links?
Nice bro...
Color shift trim?
Color shift trim?
Nope, just some crafty spray can work. Probably going to wrap that soon though, not crazy about the look
Nice bro...
thanks bro
Since you are only looking to do the seat backs I have only drawn that part of the process.
This is the link to the product I ordered. You will get 4 pads total: a butt and back pad for each seat.
http://www.amazon.com/gp/product/B008D2LIRG?psc=1&redirect=true&ref_=oh_aui_detailpage_o03_s00
Here is the front of the seat. The shaded area shows where the pad is located. That whole large panel is accesible, from the crease of the seat all the way up to the style line.
Here is a side/section view of how the seat cover works. it starts at the long clip in the back, goes between the seat back and the seat itself, up the front of the seat back, over the top, down to the long clip again (attaches to itself there), and has an extension that leads under the seat.
Here is what is going on under the seat. The extension has 2 clips that attach to the springs on the bottom of the seat. These are easy to pop or slide off.
Here is the back of the seat. The long clip runs the whole width of the seat, and the side view of the clip shows you how they lock together. Instead of trying to fight against the clips, I unzipped the zippers and used the slack from that to slide the clips apart in opposite directions. This still was a lot of pulling, and I had to flex the clips a bit, but it was way easier than trying to fight those clips.
Putting the seat cover back on I just used the long clip normally instead of trying to slide the two back together.
Cabling is the easy part for this one :)
I hope this satisfies your curiosity, if anything is unclear/any questions feel free to ask
I dont know if this relate, I have heated seats, but looking in racing seat... Do you know if I can transfer the heating system to those from my old seats?
@T-Flash:
I'm not sure. If they consist of a pad sitting between the seat cover and the foam then probably, if they are more heavily integrated into the seat then maybe not.
Another update:
I removed my fog housings. After 2 years of running 35-Watt, 6000K HIDs, the reflector housing has almost zero damage. One of them has some bubling and cracking, but that one had almost an inch of water in it from this past winter, so I think the heat of the lamps + the water caused the issue. The other one looks great and didn't have standing water. If I had gone with the 55-Watt HIDs I think there might have been reflector damage.
Projector Fogs: Fitment isn't perfect but it still looks good, I'll come up with something to close the gap. Not wired in, just placed.
Vortex Fins:
Sweet dude. I am doing a retro on mine since they need some repair but I need to find some way of making some parts water tight. I thinking water proof silicon wrap.
I just picked up some black silicone adhesive, going to seal up one of my door edge protectors that keeps coming loose. That could be an option for sealing some parts that need to stay black. You going to Newtown this weekend?
No they messaged me and told me not to bring the gang as they won't have the space for imports at the sshow. They are only doing domestics :/
That sucks, but more time to sleep I suppose.
Was going to save this for a reveal:
Did you put halos around your Hella Horns?
that's pretty cool I must admit
Hellas are still on the to do list. The projector fogs came with halos, I whipped up a bracket and mounted them behind the grille
Thanks!
STI lip install: http://www.amazon.com/gp/product/B008WGOF3M?psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s00
Took about 4 hours of dremel work, then another hour of pushing, shoving, swearing, and screwing.
Still needs a bit of work at the corners to fill in some gap. 2 gaps under the grille but I like the look so those will stay. Also need to figure out what to do just in front of the tires, the lip pinches in a bit there.
Sweet
But I thought these lips were supposed to be bolt on
