JukEboX
Need Help! Fogs Not Working With Xenon Bulbs
2 posts in this topic
Hi Guys,
So I got new bulbs for the fogs. I got a set of 3K Xenon bulbs. I put in the ballast as well as replaced the sockets so that they would it. When I turn on my fogs it sounds like there is no power gong to the ballasts. I am so confused. When I put in my original fogs they were working. But with the HIDS it won't light. Can anyone help?
Usually when you run HID systems, you need to wire a relay harness in with it. The ballasts hook right up to the existing fog light wiring harnesses. Then there's usually a power wire which goes straight to the battery. There may be another wire, which triggers the relay, which you would need to splice into another wire somewhere either in the engine bay or the interior fuse box. I can't specifically remember, so someone else may need to comment and provide their input. I haven't had HIDs since my last car, and it's been a while. Hope some of this helps.
