sebass
My 2009 Lancer Gts Turbo Build
59 posts in this topic
Here is my 2009 Lancer GTS 2.4l 5 speed Turbo Project:
Parts installed:
Caliber srt4 Pistons and Rods + Rod Bearings
Caliber srt4 Cylinder Head Gasket
Evo X ARP Head studs
Evo X ECU
Evo X turbo and manifold
Evo X Injectors
Evo X Fuel Pump
Evo X Intercooler and piping
Evo X modified down pipe
Evo X top radiator hoses
Clutch Masters FX400
Evo X Blow Off Valve
Kinugawa Evo X Waste gate actuator with 1.2 bar spring
Ralliart modded air Intake
K&N air filter
Custom 2.5" exhaust with stock muffler + Electric Cutout.
Engine bay
317HP @ 5215 rpm and 356lbft @ 4156 rpm with Virtual Dyno
Dyno26july2013-217HP356TQ_zpsd517c90f.jp
Engine removed
Starting desassembling
Oil pan removed
Bridge removed to access the connecting rods
New Dodge Caliber srt4 pistons/rod on the left. Look at the difference on thikness of the rod...
Top of the pistons
New pistons and ARP studs installed
New cylinder head gasket
Evo X turbo with Kinugawa Actuator
Turbo installed with manifold
New Spec clutch installed, I replaced later on with a Clutch Masters FX400. The Spec clutch was not able to support 350lb of torque.
Engine ready to be installed
Engine back into the car
http://i294.photobucket.com/albums/mm84/the_fish007/DSC00031.jpg
http://i294.photobucket.com/albums/mm84/the_fish007/DSC00035.jpg
http://i294.photobucket.com/albums/mm84/the_fish007/DSC00037.jpg
http://i294.photobucket.com/albums/mm84/the_fish007/DSC00036.jpg
http://i294.photobucket.com/albums/mm84/the_fish007/DSC00032.jpg
http://i294.photobucket.com/albums/mm84/the_fish007/DSC00025.jpg
that looks really really nice man!
i'm assuming the top of the piston is wayyy lower on the caliber ones,
what about the headgasket difference???
do the pistons and rods went in without any mod???
regards,
G.
daaaayyyyyyyum this is awesome! nice job bro
regards,
G.
Thanks! The pistons are from a Caliber srt4 and there was not mod to be done. I think that the gasket from srt4 has one layer less than the lancer.
Thank you!
Wow. Just wow. Welldone
Stock intake?
Stock intake?
Yep
Interesting man looks good that is a hella scary for me to do lol. Ive taken an engine apart but that is scary on my daily and Im still payin the car. Keep it up man!
Damn! That looks good! Too bad I have a CVT, I would have loved to use your build in my 2.4l engine
Holy Beast!! Great build man!
Thank you guys!
So you basically used the Evo X turbo kit? Everything fit okay? I heard that you can install the turbo without having to upgrade the internals but is recommended if youre aiming for higher HP. And do you really need an Evo X ECU? Or can you just tune the stock GT ECU?
Everythig fit ok with minor mods. You can tune the lancer ecu but you'll have p0365 code and your mivec will not work.
Okay, so an Evo X ECU is a pretty good idea then. Thanks!
Great work! Bet she's a beast.
Great details. :thumbsup:
I was also looking to do the exact mod. except for the caliber piston+rods for now. 317 hp is a great number for a 170 stock NA engine.
Did you tune further with the Evo X ECU or is it just bolt on and that is all? what boost are you running ?
Cvt doesn't matter can and has been done plan on doin this to my Cvt over the next couple years
Great details. [emoji106]
Thanks! Any ecu you will use has to be tuned.
I'm boosting 18 psi.
where did you find your evo x ecu?
did not knew 4b12 could handle that kind of psi with forged piston and rod. Wonder how much the stock piston setup could handle.
My same question. I want to boost the 4b12 but wouldnt want to stress the stock rods and piston to the point of breaking
