Remko_S
How To Flip Key Conversion
6 posts in this topic
Because some people asked for a How To for the flip key conversion of the Lancer. I show how i did this in this topic. (In my best english) But photos explain every step
large.56bb322a20c23_2015-06-1422.08.27.j
What doe you need:
- Your key for the inside (buttons and ignition chip)
- A flip key shell for your key
- Optional a new battery (it is open so why not)
Step 1:
Choose the right shell for your flip key conversion. Bought mine on eBay:
http://www.ebay.com/itm/131484761560?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
This seller has shell for a lot of keys. But you can choose where you buy it yourself.
1363573966_16_PB_4178_0.png.6e187aaf7238
Make sure that the key-blade is the samen as yours and the buttons of your own key fit the shell before you buy it.
Step 2: Cut the key blade
Let a locksmith or the dealer cut the key-blade to match your car. Did this first so i was able to test it right after i installed the internals.
Step 3: Open your old key
Take the screw out of the back and you're able to see the internals
large.56bb31fd739a6_2015-06-1421.50.47-2
Take out what you need:
- Buttons
- internal bit for buttons
- ignition chip
56bb315ce0a6b_2015-06-1421.54.15.thumb.j
Optional: replace the battery of your key
56bb313012b4c_2015-06-1421.56.54.thumb.j
Step 4: Place the parts in the flip key shell
Open the shell
56bb30f42572d_Naamlooskopie.png.b5d66861
place parts in the shell. Tip: place the ignition chip in a little drop of glue so it can't move and make any noise
large.Naamloos2.png.491de83c5a9c1190fcc4
Place the key blade
large.Naamloos3.png.30bd804481a373d732f5
place the back cover in a counter clock wise move to set the spring
large.Naamloos4.png.0485ab139abfd4144ae5
place the screw back and finish it with a little sticker
large.56bb3214f22d6_2015-06-1422.08.20.jlarge.56bb322a20c23_2015-06-1422.08.27.j
Did this for both of the keys of my lancer and the ford of my sister
I've really been meaning to do this, this helps a lot. My key is like about to break hahaha. Good how to, thanks a lot :D
I did mine as well back in the winter time.
I just purchased the casing from Ebay which you switch over stock internals to new key, then get the key cut.
$25 after it all.
I like it :D
look different..how?
I've got a different key. Maybe because i'm from Netherlands in Europe. Don't have a panic button. Not sure
