jluster96
Need Help Identifying Leak!
2 posts in this topic
So I was under my car yesterday and saw that there was some oil residue on my oil pan. At first I thought it might have been coming from the drain plug. being warped or not tightened securely or what not. I soon realized that higher up in the engine bay (from viewing upwards) that the bottom of my alternator was covered in the same fluid. So the fluid must have been dripping from that. I got out from under the car and looked from the top and saw that the top of the alternator was completely dry. So whatever is leaking must probably be some gasket or a hose or something. Anyone know what might be nearby that area that could be leaking? It is a orangish brown color. If anyone knows anything that would be much appreciated! Or does anyone happen to have a diagram of everything in the engine bay so I could visually diagnose? Thanks Guys!
No need for multiple threads asking the same thing. Locking this one. Use your other thread you made.
Guest
This topic is now closed to further replies.
