KDMShark
2008 Lancer Bulb List
68 posts in this topic
Front of car:
Front turn signal light: 21watts bulb: WY21W
Head light, high beam: 60watts bulb: 9005 HB3
Head light, low beam: (halogen bulb) 51watts bulb: 9006 HB4
front foglight: 55watts bulb: H11
Front side marker and parking light: 5watts bulb: WY5W 194
Side turn signal light: 5watts bulb: W5W 195
REAR of car:
High mounted stop light: ---watts bulb: -----
License plate: 5watts bulb: W5W 194
back up light: 21watts bulb: 7440
tail light: 5watts bulb: W5W 194
tail and stop light: 21/5watts bulb 7443
rear turn signal: 21watts bulb: 7440
rear sidemarker: 5watts bulb: W5W 194
INSIDE CAR
Trunk Bulb: A12V5W x 28mm (festoon)
Dome Bulb: A12V5W x 31mm (festoon)
Oh well, I got it now.
Trunk area and dome light bulbs are both festoon bulb with a length of 28 and 31mm (actual measurement). Like the image below.
So, basically the specs on stock trunk area light bulb is A12V5W x 28mm. While the stock dome light bulb is A12V8W x 31mm.
As per autolumination's display of replacement LED festoon, the shortest is 31mm. I tried to fit the 31mm to the 28mm socket holder, and it just fit to its flexible terminals. So, we are good with 31mm length.
That's it guys, this is my little contribution on the bulb thing. :D
-Lancer08
Credit Given to Jake26
oh great this is what i was just looking for, im gonna get my xenon kit on in a month or less !
its a 8 watter but i dont know the actual manufacture code ill look it up
Well I was wanting to get blue leds. so what do I need to know? Will any 8 watt led work or do I need to know what kind of sockets they are. It would be a great help if you could link me to a set of leds that would work. in other words, find them for me online lol. Thanks in advanced for any help.
PS this is probably the most useful thread I have read on 08 lancers, thanks.
Tell you the truth im not to sure you need to open up the compartment and see but there is a socket there and i dont know of any led's at the moment that would fit into that but i could be wrong
To my knowledge, 8 watt LEDs do not exist, and if they do, they would be as bright as a headlamp LOL
At the moment, http://autolumination.com/ is the only site that I know that has a vast variety in LEDs... your best shot will be dismounting the housing and taking out the bulb... it usually has a number of somthing on it... that number will be the model of the bulb.. then just search it in that site or "google it" :rolleyes:
hopefullyt this helps :)
Does anyone know what the size od the LED inside the instrument/Gauge cluster ?
is it nay of these 74 17 18 37 70 73 79 85 86 2721 ?
will this fit the dome lights? both front and middle of the car?
http://www.racinglab.com/pixtremsupwh.html
EDIT: if so, the model is T10 (but its 10 watts) so i doubt it because Dome Bulb: A12V5W x 31mm means... A 12 volts 5 watts 31mm long.. but whats the model?
does anyone know where I can get some yellow fog bulbs? Bc when i search for h11, it comes up as bulbs that look like my headlight bulbs which im assuming is wrong
Yes sir, here you go.
Option 1
Option 2
Option 3
As you can see the brand is Nokya. Thats what 90% of us here are using. Excluding the memebers with HID fogs, and PIAA fogs.
does anyone have a picture of there foglight? Like a how to because i tried taking mine off an it wouldnt come off
Does anyone know what kinds of lights are use in the little under dash area where the aux jack is? I want to put the same bulbs on either side under the dash to light up the floor.
would a size 9007-3 HID fit for the low beam?
9007-3
9006
No. It wouldn't fit nor work. Our bulbs are 9006. Stick with that.
^The information is in the first post.
front foglight: H11 bulb, 55watts
so is the city light the WY5W 5 watts?
Yes. You know all of this info is in your manual. B)
Come on now ZERO....the only reading I do is here on PL
(l) (l) Well than your reading the good stuff lol.
are all the bulbs in the 2008 lancer the same as the 2009 lancer?
Yes bro.
Is the stock HID bulb in the 09 lancers with the touring package a 9007-3 bulb?
