KDMShark
2008 Lancer Bulb List
68 posts in this topic
yea =) thanks man lol it did help
:-c2 Np. :hth
will i damage my car if i put h11 35 w in my fogs? instead of 55 w
Technically the 35w is recommended for fogs because the 55w generates a lot more heat, and the fog light housing isn't big enough to have sufficient cooling, thus having the possibility of melting something.
:-c2 Exactly. I got 35w 3k in my fogs for that reason.
are these the same bulb sizes for the 2010 gts???
Most likely. You can always check your manual to be sure.
yeah thats what i figured too
This is going to be a dumb question I'm sure, but I have to ask.
What are the real numbers for the front turn signal lights? I try searching "WY21W" and never come up with anything. Are the 7443's or 7440's or what? I know they are single filament, but which one is that?
7440
So I've been going crazy.. And the manual litterally does NOT state the bulb size for the bixenon HID projector headlights.. I'm assuming they are D2S bulbs, but is anyone 100% certain?
Need to swap mine out for a higher temp asap.
To my knowledge, the majority, if not all, of stock projector bulbs are D2S.
Alright thanks Carlos. I'm buying some Morimoto bulbs from TRS... We'll see how this turns out.
do all those 194 leds that they have on autolumination work on our car which 1s should i go with for the citys and license plate lights and for reverse
Anybody??
Most of the 194 bulbs will work, just watch out for the tower ones cause they may be a little long. your going to want a forward and side facing led for the maker lights and just forward facing for the license plate lights. as for the reverse that ones a little tricky, I'd try the wedge matrix ones and see how you like them...if you don't they are only 8 dollars a piece so its not that big a deal lol...if those dont work for you go to a tower SMT bulb
Q: can you hook up a light source that is 12v to the front turn signals? i see that it is 21 watts and curious if its too much and will burn the connections to the 12v, or too less and not turn on....?
