Sean lancer GTS 1990
Overheat
15 posts in this topic
I have a 2011 GTS I change the water pump I changed the thermostat hoses radiator fans radiator itself oh my relays heater core temperature sensor new head gasket does not have checked for warp heads cracks still overheats
Edited by Sean lancer GTS 1990
Forgot to add something
Morning,
Using proper coolant? Have you flushed it? Thoughts on a aftermarket radiator?
Sincerely,
Sepelio
I am using Factory recommended coolant yes it has been flushed due to everything is brand new and I have aftermarket radiator already
Good afternoon,
Sounds like a computer/sensor issue then.
Sincerely,
Sepelio
How bad was the old headgasket
Have you checked your engine fans? Start your car cold and with the a/c on both fans should be turning
If they aren't turning get your self some alligator clips for 10 bucks from auto zone and disconnect each fan individually and jump it straight to your battery. Test both if they dont turn. Then replace your fans... if they do work then it could be your relays or the connector thats in the middle of both fans.
Everything is brand new with the fans the fuses relays and everything still overheats fans are brand new and everything works
How exactly is it overheating, in particular - how is the fluid level in the expansion tank? Does the car push coolant out of the pressure cap on the radiator to the expansion tank, which then overflows untill enough coolant is lost? Because in this case I would recommend checking the radiator for exhaust gases, there are some easy tools for that that react to carbon monoxide fumes by changing color. If you confirm exhaust gas leak into the cooling system you can go back to the headgasket, or maybe EGR valve leak - it also has coolant passages.
This is 4B12 engine with leaking head gasket on cylinder 1, photo from last weekend, gasket was leaking from as early as 110k miles, small leak only on high load and high temperature. No drop in power whatsoever, but exhaust gases in cooling system did push coolant out from radiator cap and expansion reservoir.
The gasket was eventually changed, no head flattening or honing required, changed the distribution chain and tensioner as well and the car is back on the road with problem completely solved. The gasket was actually broken, i would almost dare to say that there was a fabrication defect/weakening, so don't underestimate that the gasket could be leaking although no all symptoms are there. Exhaust gas in coolant radiator is the biggest telltale.
It was the catalytic converter not letting enough hot air pass through put a test pipe in stop overheating
