KDMShark
Stock Engine Specs
6 posts in this topic
Engine Type 2.0L MIVEC I4
Engine Code 4B11
Valve Train DOHC, 16-valve, Mitsubishi Innovative Valve-timing Electronic Control system (MIVEC)
Displacement (cu in./cc) 122/1998
Bore x Stroke (in./mm) 3.4 x 3.4/86.0 x 86.0
Compression Ratio 10:1
Horsepower @ RPM (Fed./Cal.)* 152/143 @ 6000
Torque @ RPM (lb-ft.) (Fed./Cal.) 146/143 lb.-ft. @ 4250
Engine Block Aluminum
Cylinder Heads Aluminum
Redline RPM 6500
Fuel System MPI
Emissions Fed: Tier 2 bin 5 / Calif.: PZEV
Radiator Core size (mm) 700x409x16
Engine Oil Type 5W-20
Engine Oil Capacity (qt./l) 4.2/4.0
Alternator (Amps) 120A
Any idea what the compression PSI is supposed to be, for a compression test?
Rise, rise from the dead topic!
4B11
210 psi stock, 150 psi minimum, 14 psi max difference between cylinders
4B10 and 4B12 are +14 psi on both, 4B11T is -60 psi on both
A difficult question, on the 2.0L 4B11:
How much the stock fuel injectors flow?
I know that someones use 560cc injectors when using 11psi turbo.
There are 750cc, 1100cc (to be used on X, allowing it to run on E85 or alcohol - E100) and 2160cc injectors.
But I would like to know how much the stock injectors flow and do my own calculations and choices.
I was able to find the stock part number, injector model... but google is not able to tell me its outflow.
232cc/min for the 4b11. I can't remember if that accounted for the 5% whatever. They were Bosch ev14 related.
If that helps, they are the ​JME240B , EAT305, PartNumber: 1465A029
