KDMShark
4B11 Dyno List
44 posts in this topic
wait so a lower octane for our car will give it more torque???
When you get your car from the dealer it runs best on 87. The only way a higher octane is going to help is if you get some kinda ECU flash like from Works and ask for a higher octane.
87 user.
I really don't get how the modded cars are getting less hp and tq. someone please explain.
Lol ^^^ thats true too. I thought the 08 GTS had the 4b12 but guess, is it new to 2009+?
Nope, the GTS had the 4b11 (2.0L, 152hp crank) in '08, and then Mitsubishi realized "Holy crap, we're making this nice looking car that looks fast, but it isn't.", so they put in the 4b12 (2.4L, 168hp crank) to speed it up a bit.
The 0-60 improved by a healthy 1.1 seconds, and the 1/4 mile to a rough 15.8, up from a 16.9 in the 2008 model year. [source: Edmunds.com]
you have to take environmental differences into consideration as well as dynos. Not all dynos show the same numbers. Altitude, Hummidity, and Temperature also factor into dyno differences. A stock 4b11 in Vegas will dyno better than a 4b12 in Seattle if both were on the same dynos... You can think of it in this manner "Engines function similar to your body. You need oxygen for energy so altitude, and humidity effect your running routine, this is why Olympians train in high altitude areas to build lung strength/capacity so they can run better in lower altitude competitions. Your engine needs air as well, so in a higher altitude your engine will struggle more when ingesting oxygen than it does in a lower, less humid climate." So you really can't compare numbers from cars across the continent/world. It's best to only look for vehicle dynos in your area to get a ball park of what mods will do what for your car. This is the reason most companies refuse to give dyno numbers for products because there are so many different factors to consider, and they don't wish to misrepresent their products.
Hopefully this helps =P
I am sorry, but I have to agree those are some seriously low WHP numbers for modded N/A cars...
My Stock 08 GTS PVEZ Manual was pulling 135WHP and 141TQ.
Unfortunately I haven't Dyno'd since adding my Tsudo Exhaust and RA Snorkel.
Then there is...
flambouyantdude's 09 GTS FED Manual W/ Tsudo Exhaust
Pulling 164WHP and 151TQ.
Then there is...
Wow, pretty nice. Does he have the cat-back or axle-back exhaust? I've got the Tsudo Header-Back and Injen SRI
^He's got the headerbkack? i think. I know he's running catless now. I dont think he had the set up he has now when we were at that dyno night that day he put it on the dyno.
do you guys dyno and and tune your cvt lancers @ d mode?
mine got dynoed in d mode and only gives out 129 whp and 127 tq but i feel it really runs better now
223hp 230 lbs tq
11psi stock motor with turbo added.
Hi Guys,
Anyway, here's my 2.0L NA Lancer dyno result: stock internals, 95 octane fuel, 5W-40 synthetic oil.
4b11 engine running on 4b10 gearbox , not sure if makes a difference.
Ran dyno for 50 runs, getting 147whp torque 191
4B10 1.8 5MT 155.49whp, 18.44kg/m torque on a dynojet dynamometer.
Mod on the list: Alutec LCP, 4-1 R3/Tonnka Header with full custom exhaust system, Evo X Cam, Evo X TB, K&N Typhoon SRI, RA Snorkel.
Will load the dyno chart later when have the picture on my pc. :)
Because Manuel is different than auto
in case you guys were interested, i dyno'd my car today here's the results
2012 lancer ES FED manual, 4th gear pull
RRM SRI, RRM Crankshaft pulley, Works ECU flash 87 octane, Greddy axle back
in case they are interested in new numbers my lancer with exhaust manifold 4B12
This is my Turbo Set up with 10PSI Ralliart Turbo Manifold with Evo X FMIC, Evo X cams, 3" Turbo back exhaust, RA intake manifold and TB
Cheers
At the wheels with 16PSI
