Extreme Dimensions
How To: Change Oil
24 replies to this topic
#1 KDMShark
KDMShark
    I Run This Place
  • Owner
  • 8,550 posts
  • Car:2010 Genesis Coupe R-Spec
Posted 19 September 2007 - 12:16 PM
1. Go shopping; 5w20 and an oil filter (you can tell the brands I chose)
2. Manual or auto, you want to pull the e-brake. It's a FWD car, so you want those rear wheels locked so you don't get killed.
3. If you have a floorjack, you want to raise the car from the front middle. The main crossmember is a perfect choice. If you're using the car's minijack, just put it at the jack points behind each front wheel (check the manual if you don't know where that is).
4. Time to keep the car in the air. Hopefully you have a pair of jackstands. If not, do what you gotta do.
5. OK, finally on to the dirty work. Crawl under the car with a 17mm wrench and a drain pan. Remove the stock bolt and let it drain. Grab a beer, because this is going to take a while. When it finally stops coming out, put the bolt back in and gently tighten it. Don't overdo this. (Torque spec unknown at the moment; will update when I find out.)
6. And oil filter wrench would be good, but I ended up just using a huge pair of pliers. In any case, just get this sucker off however you can. Keep the pan under it, because oil WILL drip out.
7. Now you want to install your new filter. Put a little bit of oil on it's rubber gasket (so it doesn't seize on the car). Just screw it on. Again, don't overdo it; 3,000 miles is plenty of time for it to tighten up (and it will).
8. OK, you're done under the car. You can let it down now.
(Do you really need a picture for this?)
9. Time to add some oil. Open the oil cap (on top of the motor) and gently pour in 4.2 qts. of oil.
10. Give the oil time to settle and then check the yellow dipstick to make sure you didn't over/under fill it.
11. Repeat about 3,000 miles later.
Credit Given to Blacksheepdj
Boost Addict
#2 Coolguy1181
Coolguy1181
  • 141 posts
Posted 10 January 2008 - 12:12 AM
make sure you start the engine before you check the level, if not it will appear overfilled... this is just untill the oil filter fills with oil. i personally wait till the oil light goes off and ur set.
#3 D4rk4n63l
D4rk4n63l
  • 54 posts
Posted 10 March 2008 - 08:28 PM
quoted from the shop manual :
#4 EVOLUTION X MR
EVOLUTION X MR
    Elite
  • Retired Admin
  • 9,891 posts
Posted 10 March 2008 - 08:30 PM
Oh well, I will not have to worry about this for awhile. I have 10 more free oil changes.
2008 Mitsubishi Lancer Evolution X MR---Interior Sports Package, Aero Package, Navigation Package
Stage 2 AMS Cobb Access Port Tuned at 25lbs of Boost.
[x]Cobb Access Port[x]AMS FMIC[x]AMS UICP[x]AMS Short Ram Intake[x]AMS Boost Pill[x]AMS Down Pipe[x]AMS Hi Flow Cat [x]GReddy Turbo Back Ti-C Exhaust System[x]Mishimoto Performance Radiator[x]Mishimoto Performance Fans[x]Mishimoto Performance Hose Kit[x]Blitz Throttle Controller[x]AEM True Boost Gauge[x]AEM Wideband A/F Ratio Gauge[x]Rexpeed A-Pillar Gauge Pod[x]Seibon carbon Fiber Front Lip[x]Seibon Carbon Fiber Hood[x]Rexpeed Carbon Fiber Side Splats[x]Rexpeed Carbon Fiber Gas Cover[x]Rexpeed Carbon Fiber Rear Lip Spoiler[x]Rexpeed Carbon Fiber Gurney Flap[x]Rexpeed Carbon Fiber Fender Vents[x]Rexpeed Carbon Fiber Canards[x]Rally Armor Mud Flaps[x]OEM Ralliart Tail lights[x]Seibon Carbon Fiber OEM Front Lip[x]JDM Cup Holder[x] JDM Fog Light Delete Kit[x]Custom Headlights Painted Black with Red Demon Eyes and Red Projectors[x]35% Window Tint[x]Black Out Front
[x]HAWK High Performance Brakes
#5 KDMShark
KDMShark
    I Run This Place
  • Owner
  • 8,550 posts
Posted 10 March 2008 - 08:33 PM
thanks for the addition
Boost Addict
#6 Seans09GTS
Seans09GTS
  • 506 posts
Posted 27 April 2009 - 08:03 PM
Hey guys, what kind of oil filters is everyone using. Thanks in advance.
#7 LANCERGTS1
LANCERGTS1
  • 913 posts
Posted 27 April 2009 - 09:16 PM
Im using the OEM filter and Mobil 1 synthetic oil.
#8 Z3RO COOL
Z3RO COOL
    Mr.Netw0rk
  • Retired Admin
  • 12,607 posts
  • Car:08 Apex Lancer GTS/CVT
  • ROTM :FEB 2008, July 2010
Posted 29 April 2009 - 01:33 AM
+1
Posted Image<br />
<br />
PSN: jo3ynwhyc<br />
Email: joey@projectlancer.net
<br />
Twitter: Joey_Mr_Nyc<br />
PL Facebook: Click Me<br />
<br />
Posted ImagePosted ImagePosted ImagePosted ImagePosted ImagePosted ImagePosted ImagePosted Image
#9 Seans09GTS
Seans09GTS
  • 506 posts
Posted 24 May 2009 - 09:36 PM
Hey guys, is it just me, or has anyone noticed that finding 5w20 oil is pretty tricky. i like using Mobil1 and its a pain in the ass to find in stores, at least the ones near me.
on another note, is it bad to change between brands of oil even if its always synthetic? just out of curiosity. thanks guys
#10 LancerRA09
LancerRA09
    Elite
  • 2,339 posts
  • Car:2004 Subaru WRX
Posted 24 May 2009 - 09:37 PM
I use Castrol GTX and Fram. I might start using AMSoil
#11 EVOLUTION X MR
EVOLUTION X MR
    Elite
  • Retired Admin
  • 9,891 posts
Posted 24 May 2009 - 09:43 PM
Whatever my dealership uses as a oil filter. Gets changed every 3000 miles. As for oil, I use Mobil 1
#12 ricardo
ricardo
    Elite
  • 1,100 posts
  • Gender:Female
  • Car:08 gts, 84 300zxturbo, 89 supra turbo
Posted 24 May 2009 - 11:33 PM
Mobile one filter with castrol gtx
road race motorsports ignition system
road race motorsports sri
road race motorsports front strut bar
road race motorsports lower truss bar
road race motorsports tie rods
road race motorsports rear strut tower bar
road race motorsports roof vinyl
tsudo midpipe
greddy ti-c
tein springs
evo8 enkei
ventus v-12 245-40/17
pioneer double din
x-factor vortex gens
rallinspired tune on 91oct
road race motorsport's employee (best mod of all)
#13 BChad956
BChad956
  • 145 posts
Posted 26 May 2009 - 09:24 AM
i'm stickin with a mits oil filter and mobil one. i
#14 Seans09GTS
Seans09GTS
  • 506 posts
Posted 28 May 2009 - 08:02 PM
hey guys, can we use 0w-20? It's the same thing, is it not? thanks
#15 Rico
Rico
    Lurker
  • 42 posts
  • Car:2008 Mitsubishi Lancer ES
Posted 14 June 2009 - 10:11 PM
I'm using Mobil1 10w30 Extended Performance 15k miles & K&N Oil Filter. No Problem, running smooth especially on highway, 110 miles daily
#16 II REDLINE II
II REDLINE II
    Elite
  • 1,930 posts
Posted 14 June 2009 - 10:13 PM
Thanks PL thats very helpful. Im sad to say I did not know how to change my oil.
#17 daveyman
daveyman
  • 107 posts
  • Car:'08 Lancer GTS
Posted 11 January 2011 - 09:36 AM
What are your guys thoughts on synthetic vs non synth?
I'm from Canada, and I read that synth is a lot better for cold-starts, because it doesn't freeze as easily?
Thanks!
~'08 Lancer GTS Blue
[x] HIDS
[x] Cathodes Interior/Exterior
[x] Tint ( 15/35)
[ ] Greddy SE Exhaust
[ ] Interior LED ceiling lights
[ ] EVO X hood
[ ] EVO Plate
[ ] Blue Calipers
[ ] Injen CAI
[ ] Shark Antenna
[ ] Smoked Tail lights
[ ] Springs
#18 KDMShark
KDMShark
    I Run This Place
  • Owner
  • 8,550 posts
Posted 11 January 2011 - 12:08 PM
I would always go Full synthetic :)
Boost Addict
#19 daveyman
daveyman
  • 107 posts
Posted 12 January 2011 - 09:42 AM
Thanks! =D
I went full synthetic all the way!
[x] HIDS
[x] Tint ( 15/35)
[ ] EVO X hood
[ ] EVO Plate
[ ] Blue Calipers
[ ] Injen CAI
[ ] Shark Antenna
[ ] Springs
#20 sibernetik
sibernetik
  • 573 posts
  • Car:2008 Lancer GTS R/R
Posted 12 January 2011 - 10:04 AM
i use Valvoline full synthetic and a K&N filter
6000k HID | LED City/Map/LP (White) | Blacked Out Bumper | Window Tint (15%/5%) | Debadged Trunk | ARS HL Front Lip | Eibach Sportline Springs | Injen CAI | TWM Short Shifter
Progress Report - Crimson Demon
