TWM Performance
Installing Asc Off Button
16 replies to this topic
#1 bsmstar
bsmstar
    Lurker
  • 22 posts
  • Car:Lancer GT 2.0 2010
Posted 28 October 2012 - 09:32 AM
hi guys
so, my lancer 2010 is not a US specs car, so i have ASC but i dont have ASC off
so i bought one from a wrecked evo owner
anyhow, i tried it and it works (it clearly says on the screen now ASC OFF)
the problem is that i dunno how to remove the dummy (the middle one in 3 dummies to the left of steering wheel) to put my new button
can you help me?
anyone who has installed OEM HID should know how if he installed the levelling switch..
please?? im stuck!
#2 EricGTS
EricGTS
    Elite
  • Super Moderator
  • 2,323 posts
  • Car:2011 Lancer GTS 5spd
Posted 28 October 2012 - 09:37 AM
i think they just push through from the back side.
If one day the speed kills me, do not cry because I was smiling. - Paul Walker  9/12/73-11/30/13
facebook.com/ericgts11
#3 bsmstar
bsmstar
    Lurker
  • 22 posts
Posted 28 October 2012 - 01:46 PM
okay, i did try that first time, but not with much force. though it didnt work :( any other ideas?
#4 EricGTS
EricGTS
    Elite
  • Super Moderator
  • 2,323 posts
Posted 28 October 2012 - 02:35 PM
maybe the other way around, i pushed one out once before, but i forget :o
#5 NLGT
NLGT
  • 109 posts
  • Car:2011 Mitsubishi Lancer GT SSS
Posted 28 October 2012 - 06:01 PM
There's small clip tabs on the top and bottom of the blanks. These need to be pressed inward to release them, they come out through the back. I used a knife to help pry the tab, as they're fairly stiff.
  • 1
#6 bsmstar
bsmstar
    Lurker
  • 22 posts
Posted 28 October 2012 - 11:57 PM
yes my friend, i thought of that too, but when i tried it they were very stiff, so i thought maybe it wil break and i stopped myself immediately.. anyway, will try it again :)and tell u if it works, thanks
#7 bsmstar
bsmstar
    Lurker
  • 22 posts
Posted 29 October 2012 - 12:28 AM
UPDATE: done! thanks everyone, here is after :)
yeah and the tab is only on the tob of the dummy ;)
#8 NLGT
NLGT
  • 109 posts
Posted 29 October 2012 - 07:48 AM
On mine there were two, funny hey? haha
Now all you need is the headlight level and the foglight switches ;)
#9 bsmstar
bsmstar
    Lurker
  • 22 posts
Posted 31 October 2012 - 09:12 AM
i have spyder HID so no headlight switch, and i have the fog switch with the lights so i dont need that :P
anyway, just a question, my ASC-OFF doesnt light up like every other switch in the car, i mean in the night, when i switch on the lights, every other thing has red led behind it except this ASC. is that normal?
#10 NLGT
NLGT
  • 109 posts
Posted 31 October 2012 - 09:50 AM
You'd have to take the case off and see if there's an small lamp behind the button. There should be. Although both my ASC style switches look different than that one.
#11 bsmstar
bsmstar
    Lurker
  • 22 posts
Posted 02 November 2012 - 12:01 AM
oh, and how do i do that?
how does your ASC look like? i know there is 1 like mine and the other has the sign of a car skidding.. any other?
#12 ahmadk
ahmadk
    Elite
  • 1,082 posts
  • Car:08 lancer GTS
  • ROTM :March 2013, March 2014
Posted 02 November 2012 - 02:41 AM
Where did you get that switch from ?
#13 NLGT
NLGT
  • 109 posts
Posted 02 November 2012 - 09:48 AM
Mine are pictured above. The Car Skidding with "OFF" on it is a factory canadian switch, the double switch with "ASC OFF" on it came from an 2011 Eclipse Spyder. You can get factory Mitsubishi switches from www.oemmitsubishiparts.com They're not cheap, but they're the cheapest I could find, unless you find them private used. I broke down and bought 2 :lol:
As for how to open the case, it's easy, but hard to explain without seeing it, if you know what I mean. There's for tabs around the edge of the case, you should be able to push 2 in on one side, and then lift/pry the case off. If there's no lamp in there, it wouldn't be that hard to install an LED with a resistor on it to match up to voltage, and just wire it into the factory ASC plug power pins so you can still dim it, ect.
#14 bsmstar
bsmstar
    Lurker
  • 22 posts
Posted 02 November 2012 - 09:59 AM
well, 2nd switch u posted isnt a lancer switch, its a combo bcuz u dont have oem fogs. i got mine from a wreck evo on ebay. bought it for 17.8 $ anyway, if i can get myself a canadian one it looks better sure, but i couldnt.. and this one i got is in all 2010+ lancers, see any video on youtube, or ask anyone and they will confirm
#15 NLGT
NLGT
  • 109 posts
Posted 02 November 2012 - 11:16 AM
I know ;)
...the double switch with "ASC OFF" on it came from an 2011 Eclipse Spyder...
I do have OEM Fogs, it's just they have the switch on the control stalk. Where I wanted to have complete control of my Fogs, I needed to add a switch, OEM Eclipse one was the perfect answer. I didn't realize it was a double until it arrived, but no big deal, it allows me to add an accessory switch at a later time if I need it. The middle switch was OEM in my 2011 GT, but again, it's Canadian.
If you do decide to light up the switch and need some help, let me know, I'll try to explain it the best I can from when I had the switch cracked open. The Eclipse one had blue lighting, so I had to open it up to remove the blue rubber that was on the lamp, and replace it with some transparent red tape. Matches the stock lighting perfect.
#16 bsmstar
bsmstar
    Lurker
  • 22 posts
Posted 03 November 2012 - 06:45 AM
thanks.. well actually, some guy promised me an OEM switch in a month, and im busy painting my RA bumper so i think i will postpone the ASC thingy now.. also, im getting an OEM wing :D
#17 Johnnyappleseed
Johnnyappleseed
  • 298 posts
  • Car:2011 Lancer ES
Posted 03 November 2012 - 09:04 AM
OEM Evo wing, or just the base spoiler?
Sent from my Galaxy S III using Tapatalk 2
OEM Mod list:
[x] Evo X hood
[x] Evo X GSR Rims
[x] Evo X Recaro seats
[x] Evo X SSS wing
[x] MMCS Navi
Mods:
[x] Rexpeed Evo X polarized rear view mirror
[x] INJEN CAI w/ Hydroshield
[x] RRM lightweight crank pulley
[x] Ported & Polished Trottle Body
[x] Carbon Fiber wrapped interior
[x] 3" test pipe
[x] Evo X style rear bumper
Next Mod:
[] OEM projector headlamps
[] Alutec strut bar (front/rear)
[] 4-2-1 headers
[] DIY Evo X style fender vents (true ventalation)
[] Tune & re-dyno.
Final mod:
[] Trade-in for 2013 Evo X GSR SSS
