Automoglow
Turn Signals/Hazards Not Working - Help!
6 replies to this topic
#1 Jason
Jason
  • 554 posts
Posted 13 August 2009 - 11:20 AM
Ok, so here's the deal. I installed my neons and tapped into the hazard light fuse.
However, I upgraded to LEDs and decided to tap into the cig lighter fuse instead.
Now my turn signals and hazards don't work!
I've tried replacing the fuse for the hazards already and that still didn't work....
The turn signal lights on the dash don't even work either...
Do you think someone at AutoZone could help me out with this? I really don't want drive 20 miles to the dealer...
EDIT: Just found out this isn't a fuse problem... I tapped back into the hazard fuse and the LEDs will turn on... -sigh- What could be wrong here?
#2 LancerRA09
LancerRA09
    Elite
  • 2,339 posts
  • Car:2004 Subaru WRX
Posted 13 August 2009 - 01:19 PM
how did you tap into them, easy splice connector?
#3 Jason
Jason
  • 554 posts
Posted 13 August 2009 - 02:23 PM
No, I just used a fuse tap from AutoZone...
Like this:
http://contentinfo.a.../85606/image/6/
#4 LancerRA09
LancerRA09
    Elite
  • 2,339 posts
Posted 13 August 2009 - 02:38 PM
idk how those work so im not sure
#5 Jason
Jason
  • 554 posts
Posted 13 August 2009 - 02:52 PM
It works exactly like this:
You just plug it in where the old fuse was.
#6 matchstick
matchstick
  • Supporting Member
  • 772 posts
  • Car:2008 Lancer GTS Aqua
Posted 13 August 2009 - 03:53 PM
Well i know this isn't a help but I wouldn't have tapped the hazard fuse to begin with...
What I think may have happened though is this...
That first fuse tap actually adds to the thickness of the male prong on the fuse, which probably expanded/bent open the female slot in the fuse box to the point a normal fuse male tip is sitting loosely in one of the female slots and not getting a connection.
You could probably with a small pin or jewel maker's tool (the really thin screwdrivers) and bend it back to make it a smaller gap. Just make sure not to cross the 2 female slots with the metal of whatever tool you are using (unplug battery).
That's why I don't like that first type you posted, and prefer the 2nd type you show.
VTEC - Sometimes you need a catchy word to let the world know your car doesn't make power until 5000 RPM.
#7 Jason
Jason
  • 554 posts
Posted 13 August 2009 - 04:08 PM
Wow dude, that actually worked.
+Rep
I'd give you more rep if I could.
You have no idea how much I was freaking out... You might have just saved me from a voided warranty!
